Configure ARP ACEs
Use ACE Address Resolution Protocol (ARP) entries to ensure the filter looks for ARP requests or responses.
You cannot configure ARP attributes for IPv6 filters.
The ACL exists.
The ACE exists.
Use the data in the following table to use the filter acl ace arp command.
Variable |
Value |
<1-2048> |
Specifies the ACL ID. |
<1-2000> |
Specifies the ACE ID. |
operation eq <arprequest|arpresponse> |
Specifies the type of ARP operation to filter: arpRequest or arpResponse. |
